we've used wi-fi internet in our house for many years. When the house was rewired we had ethernet sockets installed in some of the rooms. How do I find out where these sockets are connected to? should the connection be before or after the router?
thanks. how does the internet signal get to the ethernet socket?Into the router or via a switch if you need to connect more than 4 ….( most routers only have 4 max )
thanks, how does the internet signal get to this bunch of cables? from what I can see the cable with the signalSomewhere in your house you should find a number of cables together
Fingers crossed they will be terminated with connectors and plugged in to an Ethernet switch
goes straight to the router.
quote - "there needs to be a cable from the router to the switch". This is exactly the information I was looking for. I just didn't know how the internet signal got to the ethernet sockets in the other rooms?There needs to be a cable from the router to the switch.
Have you located the point in the house where there are a few cables
Power line adaptors can be good
I'll post pics of rooms and near the router but here are some cables that I found in the cellar. any use?Post pictures of what you have in the rooms and what you have near the router
