I'm installing an outdoor socket for our hot tub. I've gone through the wall and installed an IP66 rated enclosure, and had indented to spur off an existing socket in the living room. I drilled at the centre height of that socket on the adjacent wall to make sure the cable run will be in the safety zone, however, I failed to take in to account that the safety zones don't extend beyond the corner.
I had planned to install an two-pole isolator switch to make sure I can remove the outdoor socket from the ring if I want to, and I had planned to install that next to the plug.
Two questions. 1) Is there a best practice for the height of an isolator switch? Should it be high on the wall, or can it be at socket level? 2) If I place it on the exterior wall (at either hight) is this sufficient to create a safety zone for the cable entry once the wall is closed up?
