Portable power packs or inverters
29 Dec 2018
Hi guys
Figured someone here may know, looking for some sort of power pack, basically I need one with a usb output for a masterbuilt BBQ, and one with a mains plug too for a rotisserie on a different BBQ
Something thatll keep a charge for a while and not too pricey would be ideal but not sure what in best looking at, just want to stop running extension leads around the garden with a toddler running around
Thanks any suggestions welcome
A barbie is a sort of heating appliance, so it will have a high energy demand. Batteries are unsuitable, unless you have money to burn.
Gas bottles make more sense.
I don't understand the reference to USB output, which is only suitable for very low demand such as charging a phone.
It's only required for the...
The USB-C power delivery standard supports up to 240W - plenty for all sorts of devices.
Thanks I'll try and find the how much power the draw out.
I know others run their masterbuilt (mains powered usually) BBQ via a power bank with good battery life even after long cooks, i could do this, but ideally would get something the AC output too, for both BBQs
Show me one.
180W is the highest rated USB-C supply that I currently know of - although 240W supplies are being worked on....
Sorry to the OP if this is off topic :rolleyes:
Show me one.
John, my name is on the contributors list for the USB Power Delivery specification. What RandomGrinch says is perfectly correct. I have a 140W Apple Phone Adapter (so 28V/5A) which was actually one of the first on the market. Since then many others have become available, but I haven't been keeping up owing to retirement.
It depends on how much power and what else it will be used for this
is 2.048 kWh and output of 2 kW but I use something like this
there are now lithium versions much smaller
which do around the same thing, I was looking at one in Lidi the other day. And just USB loads around 1727001211780.png they are used to extend phone life.
A cig lighter inverter is around 150 watt max, and a jump starter built in inverter a bit bigger around around 180 watt, so it would run a audio unit, but that's about its limit. The first unit at £881 it would be cheaper to set up an outside socket by BBQ, so really they are used for things like keeping freezers running in a power cut. Or with caravans, better than a generator running.
