- Joined
- 8 Sep 2024
- Messages
- 11
- Reaction score
- 2
- Country
Hoping for some pointers on drainage. I've recently moved into a house at the bottom of a hill. The previous owners had the house extended and the driveway block paved. The land and drive all slope down to the front of the house and connected garage. There are no downpipes at the front of the original house and no obvious drainage, other than naturally soaking into the ground.
There's an ACO drain between the drive and garage, but it goes nowhere, water just sits until it overflows into the gully below it. That is just filled with gravelly soil which soon becomes waterlogged.
The paving outside the front door pools with water and the gully along the front of the house does the same. There's no apparent connection under the block paving between the garage gully (to the left of the front door in the picture) and the gully to the right of the front door. The ground all falls away towards the downpipe on the extension but there's nothing actually connected, no French drain/ buried pipe or anything.
To sum up, there doesn't seem to be any functional system of surface water management at the front of the house. Is it normal to expect the ground to just absorb it or should I be looking at getting a French drain installed and connected to that downpipe?
Thanks for any advice.
