Plasterboard question
20 Nov 2014
Somerset
Hi All,
I am converting a log cabin style building in my garden to use as a small studio. I'm putting up an inner stud frame, insulating and covering with plasterboard. However I'm a little nervous that the plasterboard needs to be moisture board rather than regular, which would increase the cost significantly. But also think I'm over thinking it. The building doesn't suffer from any moisture ingress at all. I've had it up 3 years and it's dry as a bone! So I'm just looking for some reassurance that it will be fine and there won't be issues further down the line. I'm a little paranoid about what goes on behind the board that I can't see as well.
I'm in Bristol UK if the climate plays into this at all.
Thank you.
Osb would be more suitable , less prone to damp damage and allows you to fix to wall anywhere .
dont forget that log cabins grow and shrink with the seasons, but the insulated internal wood will not move as much, so if the inner and outer timbers are screwed together at top and bottom then you run the risk of gaps opening up between the logs and then allowing water in that way.
The Tuin log cabin site has a technical section where they discuss that and give their reasons for not offering a "twinwall" log cabin.
@foxhole I think you are right. I was originally going with OSB and I think I'll go back to that.
@Mike13 I'll check that link out, thank you. It's been up for a good few years now and I'm aware it moves and how much as I've always monitored it for moisture ingress. So I'm pretty confident it should be ok.
Appreciate all the advice.
If you're confident there's no damp and it will have some kind of heating then just fit standard plasterboard.
The point is that if you fit a rigid bit of wood on the inside and screw to it at the top and bottom of the wall, then the cabin will get unsettled over the first season. THAT is what you need to be carefull of. You need to have slotted holes in any timber (and large washers so that the screws dont pull into the slot) that is vertical and screwed to the outside wall so that it doesnt let the cabin open up later. By design they stay self settled because of the weight of the wall and the roof.
