As it looks on my screen:That's a whole new world of I.T Jargon to confuse me, I've gone into my profile, searched to give access and failed![]()
Actioned - Thank you for the tuition.As it looks on my screen:
For simplicity sake, use a short cable, connect it, complete the setup and check it operates in the house.Cat5 is connected to Lan Port 1 on the house router and into a Lan Port on the TP link "probably no.1" I have WiFi but no internet, I've gone back
Shouldn't this be the WAN or Internet port?and into a Lan Port on the TP link "probably no.1"
Sorry it was in the WAN port on the TP linkShouldn't this be the WAN or Internet port?
I used the shorter cable in the house and the Internet on it worked.For simplicity sake, use a short cable, connect it, complete the setup and check it operates in the house.
If it then doesn't work in the garden room, it's likely to be an issue with your new cable.
...and looking up the C50 (is it the AC1200?) - it's a router rather than an access point - hence the added complexity...
Did you follow the instructions to set up access point mode?...
Try and answer everyone, I used a network cable tester, the master at one end and the little one at the other, the numbers sequenced correctly from 1 to 8 so there's no fault in the cable.To prove a point ….plug in the cat 5 cable and plug in your laptop at the other end …can you get an internet connection ? If not then it’s a cable fault …..how did you test the cable ?
That's interesting, I have a selection of old routers which I put into service on a private network as required, I use a LAN port and use as a hub and WiFi, however there is no internet access on the system.Shouldn't this be the WAN or Internet port?
There would be no need for any changes to the config, if it worked in the house.I used the shorter cable in the house and the Internet on it worked.
