Hello. I'm thinking about an extractor fan when refurbing a shower room. I won't be doing it myself but I want to understand the best way to achieve what I want/don't want given what I've already got:
I don't want the fan to come on every time the light comes on
I'd like a fan with a timer or humidistat.
I don't want a pull cord as a part of the solution.
Outside the shower room are three fused switches on a ring circuit at knee level. None are currently in use.
Is a 3 pole isolation switch always required?
Does a 3 pole isolation switch mean you can wire the fan into the lighting circuit but keep the fan off even when the light is on?
If so, could you have the fan on when the light is off?
If so, does it mean running 3 core & E from the lighting circuit to the isolation switch to the fan?
Could one of the fused switches be taken off the ring and used as the isolation switch? (Handy as it's at knee level)
Is there a simpler way - e.g. what would be required to run it off the ring circuit?
I just want to be able to control the fan irrespective of the light being on or off (and no pull cord!)
Thanks in advance
Thanks in advance
