Looking to fit 2 in line extractor fans on some plywood base screwed to joists. Any recommendations for something I can use to reduce the vibration / sound?
Cheap option is carpet underlay ,(mouse mat) between ply and timber and also under fan legs.
Some fans come with rubber feet.
I hung my fan from rafters on springs and found effective .
There will always be some noise from duct connections .
The reason I asked for make was because he stated he hung it from rafters so I was wondering whether the make and model he used had a hook that allowed him to hang it on the rafters
How much gap would you deem sufficient under the door?
