- Joined
- 17 Oct 2005
- Messages
- 220
- Reaction score
- 3
- Country
hi all. Our Grant condenser boiler with a RDB2.2 Burner is not firing up properly. its stopping and starting in a loop, terrible smell of unburnt kerosene in the air.
Things I have tried today so far.
Cleaned Photocell with cotton bud - Photocell and black rubber shaft has load of black soot on it.
Unscrewed Filter at bottom of Kerosene tank and a cleaned fair bit of crap off the filter and cleaned the bowl - put back , still doing same not firing up (well goes to light but then cuts out, goes to light again in a loop) - Radiators in the house are all getting hot still …
Tigerloop glass bowl is all full of kerosene - tank has plenty of kerosene in it so not sludge at bottom of tank issue.
Next I was going to try look for filter in the oil pump and give it clean if needed - then after that clean main burner jet filter just in case thats blocked or even replace main jet if needed.
Am I going in right direction, anything else I should check or any other filters I have not mentioned?
thanks,
Andy.
thanks,
Andy.
