- Joined
- 12 Oct 2024
- Messages
- 276
- Reaction score
- 59
- Country
Hi everyone,
I'm looking for advice please.
My bungalow includes a hideous early 70s extension. They used metric bricks instead of imperial, a non matching colour, a nasty cheap looking brick and the mortar joints are terrible. A lot of it is virtually sand that disintegrates if you run your finger along it.
Now, I could get the whole thing repointed. It'll still look rather ugly though. I could get it rendered although that has shortcomings as well. Rendering would technically need planning permission and even building certificate if more than 25% of the outer walls of the house, and this would be close. In any case, people will always wonder what is behind the render and I have concerns about the long term stability of such badly constructed walls.
Other option: replace the outer brick walls with new matching imperial bricks. A builder intrust has said he can do it for about £4K and it would take a week. Render would cost near 2K so could be worth it. The rubbish cavity insulation fluff can be replaced with proper insulation and the horrible fascia above the door can be replaced by bricks sat on a lintel. He would build up from just below the ground surface unless the existing bricks down there are in bad condition, in which case those would be replaced with concrete block. Existing wall ties will be used or new screw ones added. The flat roof will need to be propped as it partly rests on the outer bricks.
Is this feasible and worthwhile given proposed cost? I attach a photo - the long side of the extension goes back to the white gutter. It might not be obvious but close up the masonry is ****. Also, are Building Control going to be a pain?
