I think the iboost+ can have two immersion heaters connected to it, and it does heat top first then bottom, but I think in the main there are no change over contacts on British immersion heaters, so it does not heat up as he describes.
But if you really want to see a clever method, then look at the Willis system, with the immersion outside of the main tank, and heating the tank from top down, not bottom up, but in main land UK seems we are too "tick" to work out how to do that. Seems they do use it with solar, but I would not install it in Wales, as to find a plumber who knows how to install it, would be hard.
shows how wired.
Not quite the same as the USA system, but it does the basic same thing.Dual Immersion Heater Operation
The Solar iBoost+ automatically detects when two immersion heaters are connected.
As hot water is drawn from the upper part of the tank, it is important the heaters are connected as shown so that the Solar iBoost+ can automatically give heating priority to the top heater.
Excess generation is diverted to the top heater until temperature is reached and the heater thermostat opens. Solar iBoost+ then automatically switches to the lower heater to continue to divert excess generation until the lower heater is also satisfied and ‘Water Tank HOT’ is displayed.
When diverting to the lower heater, the Solar iBoost+ will periodically (every 15 minutes)
switch to the top heater and the cycle of heating begins again. This maintains the temperature in the upper part of the tank.
An indication of the current heater being supplied is shown on the ‘Heating by Solar’ display.
This operating mode is the same whether diverting excess generation or in boost function.
Have you used stored domestic hot water for a shower? I have in mother old house, she had a power shower, so it used a lot of water, and a standard 40 gallon cylinder, which never ran out, so why bother with two immersion heaters? ThisI wonder why we never see that, in the UK?
was the traditional UK immersion heater, 1950's the idea was only heating the top cost less. And with so little insulation that was correct.Have you used stored domestic hot water for a shower?
so why not simply use a bigger tank. A larger tank would mean he has more ability to store energy, I have been considering a longer immersion heater, to store more energy.If you need to find a tradesperson to get your job done, please try our local search below, or if you are doing it yourself you can find suppliers local to you.
