A Spiral Table
17 Aug 2010
Been asked to do a spiral type table, any thoughts
have drawn these on fusion, can't think what to do in the middle
supposed to be ready for xmas (they can't mean this one coming can they?)
my wife says the one on the right looks like a spider, and I think the one on the left looks like a jet engine (its for an enviromentalist, they won't want a jet engine?)
They remind me of a Viking war board.
Perhaps you could fit a central boss with a solar sigil?
Or, depending on the dimensions of the table, a 'lazy Susan' could be set to spin in the center, like a table in a Chinese restaurant.
aye, I don't want it to look like a shield
I asked GBT for a design
Yeah right - I'm going to make something with such poor legs - I think not - I like a shapely leg
Seriously though I don't think Ai has knocked many nails in let understands what wood grain looks like
A cut-off piece with the natural wood grain would look good...
like this circular pattern.
A central column always looks apt, but it depends on the dimensions.
on the left makes me think nature as a common way off growing in nature your thoughts and interpretations dont matter but theres do :giggle:
I have thought of doing something like that with pitch Pine i love the two tone grain it has, don't know if it would look a bit too much - I have a big plank of douglous fir I got out of the river a few yeas back, that might work
anyways, back to this table, I have a warped bit of (probably mahogany), cut it in half, joined it back together and levelled it off so as its true
have a slightly different design now (although not sure what to do in the middle)
using beech for the light colour, although the grain could have been nicer (but I only have what I have found rescued or been given
So I am gluing these bits on first, then the first hard bit, inlaying a dark wood between them
really really nice job so far bet your pleased
assuming 12mm ply i would cut them in pairs [2 thicknesses at a time] with second one different side or area off the board to allow mix and match for extra choice and off course the possibility off another table iff nothing goes wrong ;)
Not really , like all these things they never go according to plan - the Beech that I am gluing on top is 3mm thick, and as soon as I applied the PVA it starts to warp, which has made getting it to stick where I wanted to rather awkward - I could have screamed at it, never seen wood do that so quickly, within 15 seconds it was wanting to go banana shape
ahh ok 3mm thick[1/8 inch] its quite thick for veneer usually about 30% that thickness
i wonder iff it was roll cut as in from a round log meaning it has open grain on one surface compared to the other as cut like a swiss roll ??
actually looking at your picture the grain is massively long so indeed roll cut hence why i though it was ply as its 10x plus longer between growth rings that you will get with rolled veneers compared to sliced
It's not really a veneer, I make my own bits of thin laminate from scrap wood, stuff I dig out of skips or get given. I cut it (repurpose as it seems to be known, on you tube) to about 5 or 6mm thick and then shove it through the planer/thicknesser and bring it down to just under 3. after its all glued down hand planer and scraper with take another mm off.
I have cut some Sapelli (i think it is ?) tonight for the dark bits
You're correct about the Beech, It is not a good cut of wood, basically I wasn't careful in choosing a better piece with nicer grain.
so much nicer when you get the grain right like I did on this one, Beech can have a lovely finish
ahh ok that makes complete sense ---a man after my own heart but here its as an example 6mm thick cut from for example a big chunk off oak perhaps 4x2x9" long no good to man nor beast but cut into sort off tiles say 30x60mm or 45x90 including some end grain for extra variety and gleued onto 12mm ply to make patterned small table tops /pot stands coasters what ever just to use up beautiful wood rather than just burn
sorry for misunderstanding --great job though :giggle:
