- Joined
- 3 Oct 2022
- Messages
- 31
- Reaction score
- 0
- Country
I'm about to make a small door canopy 60cm x 90cm on each side/slope.
There are 3 rafters at 30cm spacings. The eave slate will be attached to a batten, but what will support the bottom of the slate, as there is no bottom batten?
I could add an extra batten but it will raise the eave slate alot.
I thought about using a cloaking soffit strip horizontally which would support it but not sure it's strong enough.
I've also realised from underneath everyone will just see the breathable membrane... So is there something better??
If I cover it with ply/oab first then there'll be no natural gap between the rafters for the membrane to sag and allow for water run off... So guess I'd need to add ply, then vertical battens and then horizotal battens... But then the slates will be about 60cm (9mm ply, 25cm + 25cm) away from the original rafter and the verging mortar will look ridiculous.
Please help!! I'm definitely over thinking it now haha
