I guess it depends on the skill of the welder.....I’d go for a 12mm nut I think, looking at what’s left of the bolt head, weld it on with plenty of current and then tackle it with a 19mm socket.
John
John
It might not have looked it to you, but it was a fairly common problem. Encountered weekly, if not daily, for many of us.Gentlemen.
Thanks for all the advice. Been to a local mobile welder today; he put a large nut onto the bolt head and use oxy on both sides of the pinch, followed by water. Breaker bar and it just came loose with in seconds.
Will work them gently tomorrow but job done without drilling. So easy when one has the right tools!
Use Mapp, heat the bolt but keep the heat away from the bottom of the strut.
Take your time, you don’t want to snap it!
Use a full hexagon socket and heave away.....but replace the bolt with a new one once you’re done.
That is a definitely, not a chance in hell suggestion. It is unfortunately, not a through bolt with a nut on the other side; it's a Ford Mondeo design and that would be too easy.
I
The image shows the problem; on the plus side, I have found that my Irwin bolt extractors are very good at turning a hex head into a circular head! And I have rounded the cutting edge of the extractor.
Have tried heating with a propane/butane torch and all I managed to do was shear the socket adaptor.
As I said above, that cannot work. The bolt is threaded into the knuckle; if cut in half, there is nothing to unscrew the threaded part.
I hear what you are saying and the unthreaded section with the bolt head would come out easily, but what about the threaded part, which now, has nothing to apply anti-clock rotation? See my post 22 for a poor photo of the clamp
