My idea was that I needed a cable to the loft to feed tye nvr, would make sense being there and can then feed out the soffit to poe cameras from the nvr.
I don't think I would require anything like you have there plan on having a face plate in each bedroom with 1 or max 2 cables to it. So only need cable to loft from router to feed a switch then cables from switch down into 3 bedrooms.
1 cable up
3-6 cables down
could i run only 1 cable down and split again at bedroom Socked if needed ? Or just run 2 to each room. WiFi seems fine currently for son using xbox etc but will be good for his tv to plug in and PC.
Loft seemed easiest so not cables all over and don't really want in bedroom, surely if I use a proper box to store the electric switch and the nvr etc should be OK, it's a boarded loft so not to windy etc.
Thanks dean
1 cable up
3-6 cables down
Thanks dean
