Yes, it's a quick way to prove if the router is a problem or the fibre line is a problem. I wouldn't run it without a router routinely.I'm guessing you're just demonstrating that it can be done without a router. I'm also guessing that your usual setup is using a router (or some other box) to provide a Firewall in addition to the the one included wither your OS?
Yes, the fibre will be on and working during the engineer's Wednesday visit. The engineer will test that you have internet as far as the new router that they will supply and will leave you with that new router working.Would that mean the Fibre would be on, and working during the engineer's Wednesday visit?
The fibre will come in from the pole - does that mean the copper wire would be completely removed, and replaced by the fibre, on the day?
No, they won't touch the copper wire. No-one will remove it, it will be left in place indefinitely. They are also unlikely to cancel your existing Plusnet service. It is likely to still be working alongside your new fibre service until it is cancelled, you should clarify if it is your responsibility to cancel Plusnet.
The only thing that probably won't transfer on the Wednesday is your phone service. This often takes a while (perhaps a week or two) to transfer from the old provider to the new. The phone will continue to work over the old copper line until the number transfer takes place.
They are not going to do that, it isn't their copper wire to cut. It is probably Openreach's property.cutting the line and using it as a draw wire for the fibre,
Yes from what I can find out the leave the old open reach one where it is attached to your house, so leaving your house looking like a WW command post. You have to get open reach to come and remove it (if they will )They are not going to do that, it isn't their copper wire to cut. It is probably Openreach's property.
There will be an outside termination box first and then through the wall to the ONT inside your house and yes the inside one - it needs power.Another question, if I may.....
It comes across from the pole, then I understand the fibre connects to an ONT, and they mount the ONT outside. Does the ONT need any power?
Is it a LAN CAT6 coming out the back of the ONT, to plug into a router?
10 metres between the box outside, which will need to be near ground level, and the ONT inside.Thanks. Is there a limit on the distance between the termination box, and the ONT - do you know?
It will be interesting to see if that happens. All the ones that I have seen have a box outside and near ground level. I can't see any physical reason why it needs to be outside, but it does need to be near a stable surface as the equipment that they use to precisely align the ends of the cable and "weld" them together can't be used whilst balancing on a ladder. Let us know if they do install the "outside" box in your loft.it's all going into the loft..
