LED ceiling light
27 May 2010
Lancashire
Hello,
Got an LED ceiling light where the driver has failed.
3 output wires coming from driver. See pic.
Light used to dim and change between warm white and ice white via remote control.
Not bothered about any of this now. Just want the light to be on and at one colour.
Will I be able to use any driver at the correct output?
And which wires will I connect into the output. Red, yellow or white?
You need a 24V LED diver
With more than 2.15A <<<<< this seems a strange number. Cannot tell if it should say 2x 1.5A.
But it does say it is 54W. So you need a driver that says 24V and more than 54W.
Pick one of these.
Red wire goes in the +ve output.
Yellow and/or white goes in the -ve output.
I expect that yellow illuminates the warm LEDs. White illuminates the cold LEDs.
Thanks SFK.
You are correct about yellow for warm and white for cold.
Managed to get a 24 volt dc power supply today.
Wired red into positive and but yellow and white into negative.
Works a treat. With a nice light output and colour.
