I have an AEG extractor that is ducted to the outside. After 7 years, it failed earlier this week. I did the "tissue test" and there was no suction. Everything else seems to be fine: controls, fan noise. I assumed the motor is knackered and booked an engineer from AEG to come out and have a look at it.
The engineer, also did the "tissue-test". Same result.
He then disconnected the foil duct connected to the extractor and repeated the tissue test. We have suction!
There is obviously some sort of issue with this duct. This foil/aluminium flexible duct travels around 3 metres above the living room ceiling and then exits at the side of the house. There is a bend where it comes through the kitchen ceiling and then connects into the hood.
I am at a loss as to what is causing this (other than the fact that it appears to be the duct) and how I should replace this, given the nature of its route through the living room.
I would be grateful for any advice that you can provide. Thanks in advance.
