Hi all,
Sorry if this is obvious, but as a plumbing novice and having spent a morning reading about how frost stat/pipe stats work I can't seem to find a definitive answer, so I thought I'd turn to this hivemind.
I have an open vented system with a Worcester boiler located in the garage, and a Honeywell thermostat inside. This morning I've also learned that I have a Honeywell frost stat above the boiler. ~
Because I'm rather financially tight I've been operating the thermostat on 'manual' - just flicking the CH on in the morning for a little bit; and only turning on HW when required.
Since the weather turned colder my boiler is kicking in with its frost protection mode - great! I can see a little snowflake sign on the indoor thermostat and hear the boiler chuntering away... but I've also noticed that when this is happening my radiators are heating up too. It's not staying on for hours and hours, but I'd rather not pay to heat the house if I'm not in/when I'm asleep.
My understanding is that the frost stat being located in the garage means it will turn on the boiler when the temp is around <5deg in the garage, and that there is probably a pipe stat somewhere that turns it back off again when the water in the return pipe is warm enough to avoid freezing.
What I can't understand is whether it should also be heating the radiators when it's on for frost protection? Would I theoretically save money by turning the radiators down/off when it's doing this? Or is it just heating the water to protect the system, which may as well be put into the radiators?
Thanks very much for any wisdom you can provide.
