It's not really particularly confusing ...
Each switch has two positions - say 'up' and 'down'. Whether one of the switches is in the up or down position determines which position of the other switch (up or down) will result in the light coming on. It therefore follows that, as EFLI has pointed out, there are two possible combinations of switch positions which will result in the light being on,and two combinations which will result in the light being off - and nothing can change that.
Simples![]()
It may be simple to you but not so to me, lol. I don't pay attention to the switch position normally. I just look at the light to determine which position I need to turn the switch so if it is on, I press the switch to turn it off and vice versa but I guess from what you and EFL are saying is that there is actually a logical position for the switches.
This is helpful! I never could work out before when the light bulb is broke, what position the switch should be in and have put a bulb in when the switch is on because without the bulb, I have no idea if the switch is in the on or off position
