Possible ringing noise in socket
19 Feb 2020
Anytime I stay over at my parents house (which is regular) I'm hearing a small ringing sound in the early hours of the morning before I get up or late at night when I'm going to bed. Both times it's very quiet about the house and I then notice this ringing.
I was thinking it was the electrical socket or other electrical wire somewhere in the room. Although just yesterday the electric was out in the house for a few hours in the morning and I could still hear it.
If it is an electrical wire/socket issue could this wire still ring when there's no electric going through them..
I have it really bad and it's when your environment is at its quietest that you can "hear" it.
White noise is brilliant at covering it up.
At a jet engine test facility, buried deep in bunkers, the residents could hear the humming at night. So something outside is a possibility, if its not tinitus, mechanical equipment or a loose connection.
We had something similar a lot of years back, I kept blaming all sorts of electrical things as it sounded rather like mains hum. during building works I'd isolated the cold water (physically disconnected the pipe) just after downstairs WC/sink. for 2 nights there was no hum but 3rd night it kept me awake after reconnexion.
Listening to the pipe with a stick the hum was right there and the same was true for the neighbour.
They haven’t got an old smoke detector with flat batteries tucked away in a cupboard have they They can give off some weird noises at strange times Or perhaps some other device
No, definitely not but it might be the actual smile alarms on the ceiling.
How can you listen to a pipe with a stick
Engineers' stethoscope
A few pounds on Ebay
You can also hold a screwdriver in your teeth
Turning off ALL the electricity at the main switch may help you identify the source
As may turning off all the water at the outside stopcock. A tiny leak can make an imperceptible hiss that you only notice when it stops.
Boilers and central heating usually have an electric pump, and older ones often a timeswitch run by an electric motor.
Fridges and freezers have a compressor
