Balancing Radiators some colder than others
17 Oct 2005
Ireland
hello all can I have some advice / experiences please.
if a radiator is cold/colder than the others on the system would I be looking to open the return lockshield valve more, or less?
all rads have thermostat valve (TRV's) on which is turned up to highest (5) and radiators all bled so its no issue of air in the rads.
at the moment I have each lockshield valve turned about 1 full turn from the closed position, because if I new which was the last rad I was going to gradually open up lockshield valve as I went along and fully open the last radiator on the system. - I cannot tell which is last or first radiator on the system because all the pipes are buried under the floors and they may have been installed originally in a back to front way .
I havent got any temperature thermometer thing for the flow side so I am just touching with my fingers until I feel heat coming through.
Thank you.
Turn down the radiators that are hottest and then see if the cold radiators start to heat up.
you probably need to close down some rads a bit more than that to force the water to flow into the reluctant ones
its surprising how sensitive the lockshield can be on balancing
i'm checking every 10 minutes to see which radiators are the hottest , give them a time to heat up :)
As JohnD says, adjust the flow to the hot rads. Small rads ie Bathroom, Cloakroom etc will need the lockshield valve opened (from closed position) by a mere fraction, maybe just an 1/8th.
thanks all for your inputs and suggestions. I have just been out to boiler and pump (grundfoss clone) was set to speed number 1 for some reason - so after setting to speed 3, even though now pump is noisier of course, but all radiators appear to be piping hot now.
