Car juddering at low revs
8 Jun 2017
Hi. Looking for a bit of help if possible
Have an Audi A5 2.0 tdi 2011 and it's started to judder and shake quite a lot when at around 2000 revs. If I dip the clutch and increase revs the juddering reduces.
The clutch operation wise seems fine. I turned the engine off and coasted down a small hill and the judder was still there so not sure if it could be related to the wheel or if it's the clutch it would still be noticeable with no engine running. I've not done any clutch oil changes
It does sound mechanical and even at tickover/stationery it doesn't feel right.
When I first drive the car it's fine for 10 mins but then got progressively worse and the judder seems to come and go
Thanks for any help. Car is on 120k so maybe it's just starting to fall to bits
Thanks Mottie. I'm thinking clutch related too. Would it still jerk when the engine isn't running.
I had noticed that when I released the clutch I would get a rattle at a certain bite point too. Shifting gears is still as usual.
I see a clutch kit doesn't include a flywheel. Is it best to too the lot?
Sounds like DMF I agree, but have you checked for any codes to rule out other possibilities
Is there any knocking or thumping evident?
I agree, a DMF is likely - unless there is a misfire. Any dash lamps on at any time?
John :)
Thanks. Drives perfectly for 10 mins and no lights at all. Then just starts juddering at low speeds and then again at higher speed. Gear changes have always been perfectly fine. No knocking or thumping.
Mechanic has mentioned a DMF to solid swap which would work out cheaper. He's not checked it out yet though
Hi, I've just ran a diagnostics and get the below error on the diagnostics
Bypass flap air cleaner valve - open circuit. Code P101600
and the below error on the dash popped up when ticking over
Stabilisation programme fault
Not sure if something else now causing the juddering.
Was the clutch depressed or not, when you performed this operation?
If not depressed, what gear was the engine in?
I've had it in the garage now and it turned out to be a stuck caliper in the end. Weird because it wasn't overheating or smelling at all but the brakes were binding and causing the judder. Thanks for everyones help.
Just shows why it's difficult to diagnose on the internet.
But good news it's sorted
If it was the brakes how come it was causing a problem when stationary?
