Removing socket from wall for plastering??
28 Nov 2024
Hi guys,
I have to remove a wall socket to take back and re-render a wall. Just wondering if switching off the circuit on the mains and double checking it’s off with a voltage detector pen will be sufficient precautions to prevent me from getting a shock? The wall socket itself will need to be changed as one of the inputs is blown but will leave that to an electrician when the time comes (unless it’s something a total novice can handle safely-doubt it?).
Cheers!
How are you going to make the cable(s) safe between taking off the socket and putting the new socket on?
I wasn’t planning on leaving the removing the old socket from the cables until I have the plastering done. In terms of keeping it safe, I have no electrical experience so don’t know it it’s something I’ll take on myself but appreciate any advice!
Was thinking of wrapping the loose wall socket in a plastic bag and taping up to protect from dust and water while I’m working in the wall, and only work on the wall with the plug socket circuit switched off at the mains.
If you're going to plaster a wall round existing backboxes, there are plastic dummy fronts that you can work to. They screw into the backbox and you can plaster up to them, making a neat joint and without getting plaster inside, and remove the plastic cover afterwards. Keep the power turned off while you are working.
I got a few (you usually only need enough for one room or one wall while you work) and they last a long time. I can't remember the trade name.
I have seen a similar device advertised as a socket plastering shield.
If you are a DIYer, I favour setting backboxes in sand and cement mortar. It has a long working time, and is stronger than plaster. You need at least one screw into the brickwork. You use rubber grommets in the cable holes.
After cutting the power, you can neatly put the wires into 30A chocblocks (they are quite big) tucked into the backbox, but you should not leave them exposed when live. You can use blank faceplate as safe covers. Again they last a long time and are quite cheap. This enables you to keep continuity in a ring. I like to clean out the backboxes and cables with a scraper and small paintbrush before the new accessories go in (with the power turned off, obvs). For lighting accessories, mark and photograph all the wires before disconnecting so you can reconnect them the same way.
This worked for me .
