Hi all,
I'm having the area in the photos tiled with porcelain tiles. Previously it was gravel and and would drain into the soil underneath. However, I'm wondering if there needs to be a drain put under the outside tap that then connects with the drain that the downpipe connects to? Also how would I drain the tiled area that is adjacent to the decking? Should I look to have the drain for the downpipe changed to an open grate? I'd also like to avoid having to use ACO drains anywhere if I can.
Thanks in advance
Thanks in advance
