City fibre are doing the installWhich ISP?
I will find out in a few minutes but from the post across the street to my house does the cable only contain 1 solitary piece of fibre.It is one fibre, per 'line', or customer. I have a bit of the outdoor fibre, which was cut off as surplus, in the loft. I'll have a closer look at it, next time I venture up there.
So there is a lot of reinforcing protection in that cable then.That is my understanding, about the thickness of a hair. To joint it, they have to cut the ends clean and square, and using a microscope gadget, push the ends together, align, then heat seal them.
Yep - they absolutely cannot do the indoor to oudoor fibre joint, at the top of a ladder, or anywhere awkward..So there is a lot of reinforcing protection in that cable then.
The microscope thing and welding of the fibre is why they insist on the outside connection being at ground level or in your case a good floor in the loft
Well, 4 fibres then. He said one for me, one for next door (he tells me they are having it installed) and two spares.That sounds confused. Are you sure you are on fibre, not cable? There are no 'lines' in cable, as such, it's VoIP and so far as I can tell, the number of lines, is only limited by the data capacity of the fibre.
They must have joined mine in the wall. I have a black cable going into the house which turns to white inside going to the box thingy that the router plugs in to.Yep - they absolutely cannot do the indoor to oudoor fibre joint, at the top of a ladder, or anywhere awkward..
looks like this only its attached to the brick with an eye bolt not angle iorn. The old open reach twirly wire is much neater i think .
Well mine is now all done, pleased to say they no issues getting the ladder over my canopy but they had to drill a hole low down to fit a temporary eye bolt to lash the bottom of the ladders to.
But there was no welding of fibre as the cable came fitted with a plug attached and they have different lengths on the van and any spare gets stored rolled up inside the outside box.
No that is just a picture off the net --I should of made it clearer with some dashes "looks like this ---- only its attached to the brick with an eye bolt not angle iorn."Looks like a bit of galvanised Dexion angle. The screwed an eye bolt into the UPVC fascia, hopefully through into the end of the roof timber. Then used a sort of shackle, to take the fibre.
It does leave me puzzled as to how they terminate at the pole end?
So yes ignore the angle iron. They drilled a new eye bolt in the brick next to the old open reach one and attached the clothes line contraptionto the eye bolt
He wasn't up there long I think it must be another plug. He did say that if any fibre needs welding then its a different team that have to come out.
The cable from the outside box to the ONT was also with fixed plugs and they carry different lengths of that too.
