Well worth checking water pressure & flow rate before fitting a pressurized system. For the sake of a £15 meter & a large bucket for flow rate. Your looking for minimum 1.5-2 bar & a flow rate of 20lt per minuets "Absolute" minimum. Not sure? but you might be better with 2 bathrooms on a larger pressurized tank because when you switch the combi on it will also take the pressure away.
PS: You will also want a stop watch
