Hi, hope somebody can help? ...
I've fitted a new BG WP21ES External switched socket with neon indicator and can't get it to work. I've fed it via a new 2.5mm cable via a dedicated MCB and terminated as per instructions, but ....
All appears normal when nothing is connected (neon indicator goes on and off with the switch) but when i connect anything, (I've even tried a light bulb connected via a 13A plug so it can hardly be the Load - it's a 16A MCB) it trips one of the RCD's in the consumer unit but not the RCD feeding the MCB to the socket.
The only thing I can think is that it is the neon connections but I haven't altered them from as supplied .. I haven't tried disconnecting them yet.
