I've a double garage sized concrete slab to build off. As I far prefer working with wood my plan is..
Build
1. Drill into slab at every 600mm and chem-fix long bolt around edge of slab.
2. Lay 100mm concrete blocks on their flat around edge of slap, working as round the protruding bolts..
3. Lay dpm over blocks, then fix down a 6*2 as a sole plate using bolts..
4. Build 6*2 framing off sole plate
Any comments on this plan?
Thanks!
Build
Thanks!
