- Joined
- 30 May 2024
- Messages
- 6,569
- Reaction score
- 2,698
- Country
But your not always there for meOf course, that is what I suggested.
And did it leak?Only once have I had an immersion element which would not unscrew even with heat.
I ended up drilling 4mm holes in the element top.
Well, I had to give up on this one. Got a plumber to help. He went straight for the box spanner which didn’t quite fit no matter how many times he tried. He had another immersion spanner which also didn’t quite fit. He did seem a bit suprised. His wrench wouldn’t quite open enough for 86mm but I had one handy that would. Not easy to hold it on the nut with all the insulation but after some force and a hammer we got it out without any leaks that I can see. I think I’ll replace it regularly to save the hassle.Just my luck then. I’ve never removed one before. All ready to try to get it out and hoping I am not going to break the tank and none of the standard immersion spanners fit.
I hired a plumber to help. His immersion heater spanners also did not fit. He was quite confused. Got it out with a wrench in the end and put in a standard replacement from screw fix.Immersion heaters, and the spanners to fit them, are a standard size. Are you sure what you have is actually an immersion heater spanner?
Can you show a picture of the spanner, on or nearly on, the 'nut'?
Surely as soon as you apply any force on a nut you are inducing torque???Worse thing you can do is apply torque to an immersion nut. Pretty much guaranteed to wreck the tank.
Or he is lucky and immersion spins round due to initial torsional force, winners and losersSo DIYer turns off water at mains - tries to graunch off immersion with improvised tool and it doesn't move. Next uses extension bar on tool - puts boot against opposite wall of airing cupboard and heaves. Tank creases and splits at boss boss joint. Jet of water sprays out of split and keeps going till header tank empty and kitchen flooded.
