- Joined
- 14 Feb 2021
- Messages
- 49
- Reaction score
- 6
- Country
LolSurely not?
LolSurely not?
Have disconnected first. Some box spanners have a notch for the wire though.Why can’t it be the reason. OP might just think it doesn’t fit, they (spanners) don’t go over cables.
I am not at the flat atm so can’t get a photo. The spanner’s that I’ve tried are definitely meant for immersion heater. The ones from screw fix etc. They aren’t a lot too small, may be just a couple of mm but enough so they won’t go onto the nut at all. They fit the replacement immersion element just fine.Immersion heaters, and the spanners to fit them, are a standard size. Are you sure what you have is actually an immersion heater spanner?
Can you show a picture of the spanner, on or nearly on, the 'nut'?
Some box spanner’s have a notch for the wire but i think you still have to disconnect.Why can’t it be the reason. OP might just think it doesn’t fit, they (spanners) don’t go over cables.
It’s just getting any of the spanners to fit onto the nut. Wires disconnected the spanners don’t fit. Too small by a couple of mm.Monument do a good heavy duty spanner for the job. Hit is very firmly - a good solid blow - with a club hammer, and you will break the seal. Al the plumber does a good demonstration on his youtube channel.
Well, how else would you wire the new one up?Some box spanner’s have a notch for the wire but i think you still have to disconnect.
LolWell, how else would you wire the new one up?![]()
Wonder why some have a notch.
But I have never encountered any spanner which did not fit.
The cast iron spanners are far better than those pressed out of sheet steel.
Maybe hire a big Stillson, the handle length alone will give great leverageIt’s just getting any of the spanners to fit onto the nut. Wires disconnected the spanners don’t fit. Too small by a couple of mm.
