Hi all,
Any one done this or had it done and do you have any numbers on how the heat requirement of these rooms changed subsequently?
I'm just thinking through what the options are and if worth it for the hassle/risks i.e.
-Will it make much difference (filled cavity walls, double glazed but 20+ years old (will replace), 60's house, 270mm loft insulation fitted). Heating stats of larger room in roof is currently 62W/m2 (13m2 area 0.805kWh to maintain 15C indoor with 1C outside temperature)
-Worried about the usual, mess of having it done, (stud wall needs exposing/modifying to provide sufficient ventilation gap to roof on sloped sections), added ventilation through roof maybe required, condensation/mould/rot if not done right-industry seems like a mine field
-Might want to fit flush cupboards into dwarf walls to make use of eaves space but not sure how/if this would compromise the effectiveness of any added insulation
-Would retrofitting a warm roof be a more all encompassing solution? Roof tiles are 60 years old, will need replaced at some point. Would favour paying more if it means less internal rework to fit insulation and deal with it from the outside envelope, cavity walls/roof if possible?
Thanks for your feedback
