- Joined
- 8 Jan 2025
- Messages
- 2
- Reaction score
- 0
- Country
With this type of fitting it wont make a difference as you can fit the bulb any way but it's still nice to have the live identified if possible.Thanks to you both for your replies.
@pete01 because of what you've said that it doesn't matter determining which of the blacks is neutral or switched?
I was just going to say that.......Personally I would use 2 pieces of green/yellow sleeving. One for each earth wire, then you can see and pull test both to ensure they are connected.
Yes I agree but I'll bet a pound to a penny the existing is twisted together and secondly I'll estimate OP doesn't have any and I'd say not worth the expenditure of effort to get some.Personally I would use 2 pieces of green/yellow sleeving. One for each earth wire, then you can see and pull test both to ensure they are connected.
When I made the same suggestion a short while back it turned into one of our tomes and multiple reasons I was wrong.I doesn't really matter which Black goes where
unless the bulb is a screw in type which they aren't usually on a pendant.
What other reasons?When I made the same suggestion a short while back it turned into one of our tomes and multiple reasons I was wrong.
One of those reasons was:
Unless he lives in the sticks it's easy enough to ask any sparky for a few inches of sleeving.Yes I agree but I'll bet a pound to a penny the existing is twisted together and secondly I'll estimate OP doesn't have any and I'd say not worth the expenditure of effort to get some.
And the final result of that additional exercise? an extra 2 inchesUnless he lives in the sticks it's easy enough to ask any sparky for a few inches of sleeving.
They are often found getting breakfast in supermarkets, Greggs, Screwfix etc etc etc.
Happy soul aren't you.And the final result of that additional exercise? an extra 2 inches
