I am trying to put up a light fitting.
In the ceiling at the moment is an ordinary plastic ceiling rose with the three blocks of terminals.
My problem is the light fitting I have has only a small "cup" on the end which will not fit over the existing ceiling rose to hide it.
I've managed to wire it up correctly on top of the ceiling rose and screw it to the ceiling but it looks dreadful as you can see the plastic ceiling rose underneath.
What are my options? Could I remove the ceiling rose entirely and replace it just with a block of terminals? On the basis I could wire the block up and push that into the roof void leaving the ceiling flush to screw my light fitting to?
I have a strip/block of the plastic terminals if the above suggestion is okay, please could someone tell me how to wire it?
The wires coming from the ceiling at the moment are:
Black with red sleeve (switch)
Two more black wires
For some reason there are no reds coming into the central "loop" section in the plastic ceiling rose. These seem to be all bundled together and taped up in a plastic terminal block pushed into the ceiling void already. No idea why this is.
All the earths were bent together and pushed into the void but my light fitting is metal so I plan to use these wires with the earth from the light fitting - presumably I would need one block in my terminal to put all these wires in together?
Any guidance would be much appreciated as I can't afford to get an electrician in and would just like to get this light up. Many thanks.
