Wattage on the Rear of Light Switches
17 Feb 2016
Have you guys ever took notice of the Wattage measurements on the Rear of domestic light switches?
I've NEVER once done it myself, but I just read it, while I was pottering about on Dr Google
Does it help you guys?... Or is it just summit that's OVERKILL
Plate switches always have current ratings and are rated at 6a or 10a and sometimes 20a, ideally they should be rated to the mcb size, but as most domestic lighting circuits are 6 amp then by default any switch is suitable.
In past days you derated a switch for certain types of load, but rarely needed nowadays.
Only ever seen wattage or VA on dimmers or specialist switches
In the main I know the load each lighting set will put onto the switch, easy enough to measure, Clamp-meter-small.jpg but we are told we should consider 100 watt bulbs are used, which with LED's seems daft, but this was before LED's came out, I do watch total power used, at moment whole house using 510 watt, but drawing 4.5 kW from the grid to recharge my batteries, here I am monitoring again total house use CU use 8 Feb 24.jpg to work out how much lights use simply switch off light RCBO and see reduction in amps. But so unlikely to exceed 6 amps on lights hardly worth it.
Every so often I see a quiz on google about electrics, but in the main they are for USA only, and don't really apply to UK.
