Hi, please help,
So, we recently bought a house, Essex, UK (detached bungalow about 100 m2, 1950-1960 era) in September, we have done some renovation, new flooring(laminate), new kitchen, new bathroom, changed couple windows from single to double glazing, changed one radiator in bathroom to towel rail.
All this time thermostat was set up for 18 degrees, like I said nobody lived in a house, just tradesmen and myself recently used to come in evenings to do the job, we received gas bill for nearly £700!!! (FOR WHAT???!!!)
The new central heating system was installed in 2019.11 new radiators, new pipes, and new boiler(there are paperwork for proofs etc.) Previous owner was very proud about that and told me he was boiling in the house (obviously he could lie)...
Last week we moved in, and then.....
1. The house barely reaches 18 degrees in any room, even the heating is constantly on. Thermostat is "HIVE" remote, we tried in every room it doesn't matter where it stays everywhere shows roughly the same.
2. The radiators have TRV all set on max, the flow from boiler 65C (tried and 60C - the same), rads get hot but room still very cold, tried heating all day long, no success. 1 rad in hall don't have TRV.
3. Insulation on loft 200mm, partly boarded. Double-glazed windows in every room (quite old).
4. All radiators take very long to preheat (except towel rail, I think it's 1st in line). And most of them very hot on top and warm on bottom.
5. All radiators are "designer" modern ones. Some vertical single, some doubles but horizontal. By the way, they all 5 years old but all of them rusted on the bottom and paint flicking on all of them.(this might be important detail.)
6. Smart meter shows that we use about 6–7 kWh in half an hour, then about 3 kWh and then 0, and then cycle again. 10Kwh every 1.5 hours... it's been 2000kwh for October, more that 3000kwh for November, and more that 3000kwh for December, I can't believe that's normal. In previous house we used 25 kWh a day, and 1000kwh on very cold month.
7. Boiler - Worcester Greenstar 32CDi Compact. Service have been done in September - came as all OK.
8. I've checked on boiler's settings, and it shows that return is only 5C lower than flow. So in my case, flow 65C return 60C.
Please help where I should start from to reduce bill and get house warm.
