First is to say, I'm having an SE round Wednesday, but thought I'd ask anyway. We built our timber frame house 30 years ago. I plan to remove a 3.5m long downstairs stud (4x2 @ 600 centres) wall with a door in it, to make a through kitchen dining room.
The joists run parallel to the stud wall. There is another stud wall above it, offset by about 350mm, same direction. I don't think the upstairs studs support the fink trusses, because I think I recall the upstairs being totally empty during construction; studs in after.
Q1 Is my downstairs wall likely to be load bearing?
Q2 If a beam is needed, could it be provided by extra floor joists rather than steel?
Q3 If support is needed, can it be shoved up against the upper floorborads and fixed, so I have a flat ceiling?
Thanks for reading.
Thanks for reading.
