Led light bulb G4
5 Nov 2009
Liverpool
Good morning
I have a light fitting with g4 bulb
Would it be possible to insert g4 led instead of halogen bulb?
Would W is suitable 3w, 5w, 7w?
Some manufacturers says reqs transformers, would my current light have a transformers with halogen?
Can you directly replace halogen bulbs with LED?
You may need to keep one of them a bulb for it to work. It’s what I do.
Looks a bit odd though
Would i be able to replace the transformer?
If I left the current transformer would it be dangerous to use? Or would it just flicker
Would the transformer pic work?
Yes - depending on the suitability of the replacement G4 LED
Any wattage is suitable, provided that the Power Supply can supply it.
Let's not get into any argument !
However, that which you require is a 12 V DC Power Supply.
The MAINS AC will be "transformed" into a Lower Voltage and Rectified and Filtered to provide (rough) DC.
The device which you pictured is a 12 V, 2500 mA Power Supply.
Hence, it can supply up to 30 W total.
The "lamp" pictured appears to require FOUR G4 lamps.
Four (typical) 3 W 12 V G4 LED lamps would draw only 12 W,
4W lamps would draw 16 W etc.
G4 LEDs to replace Halogen G4 Lamps are available as either DC or AC types.
It may be best to purchase AC types,
since they are actually DC types with an inbuilt Bridge Rectifier,
so that the do not "care" if they are plugged into an AC Supply
or a DC Supply
of either possible configuration.
Hi
Thanks for all your responses.
Would it be dangerous trying the led on my halogen transformer and if it works to leave it on the old transformer.
The bulb i be fitting is below
Also will I need to replace the whole lighting
Much appreciated
Unlikely, but destroying the LEDs is likely, so is flashing, flickering and things generally not working.
If you must keep the light fitting, then the only real solution is a new LED driver appropriate to the lamps chosen.
Ebay tat
pseudobranded to appear similar to something it's not
'A star engery rated'
Good luck with that.
keep one existing bulb, replace the other 3 with LEDs. See if that works.
Keep the old bulbs as spares, and you will likely need 1 working bulb for the whole thing to function (will flash otherwise)
(If that device will operate on AC
and
the Halogen power supply is just a Transformer
or
a Power supply with no minimum output
there will be no problem.)
and
Ebay tat
flameport:-
I do not wish to be "argumentative" but
you will find that (virtually) all such devices are actually made in China !
Many such devices are available (cheaply) on sites such as this
(https://www.aliexpress.com/w/wholesale-g4-led.html?spm=a2g0o.productlist.search.0 )
These devices may be sold under other "Brand Names" - in the UK and elsewhere -
but
they are still the (usually quite well made) Chinese devices.
I have used 3 W, 12 V AC, G4 LEDs from similar sources in my 10 all night Garden Lights
(plus in another group - with 15 Lights)
for many years
and
have had only one or two "failures per year", where a replacement was required.
I must agree with @FrodoOne in fact with G9 bulbs I found local sourced bulbs were useless. The G9-comp.jpg large bulb to left, technically did not comply with UK rules, there was no lumen marked, no watts marked, however 4 out of 5 worked A1, the 5th I took apart to see how they worked, very simple, a capacitor used as a volt dropper, then full wave rectified, into an electrolytic capacitor nearly as big as the whole of bulb to right, to the LED's and a small leak off resistor. I also found a dry joint, corrected, and reassembled, been running now some 3 years.
Main point the bulb to left worked A1, the covers would not fit, but they worked. The bulb to the right had a shimmer when on, and would not switch fully off, but covers would fit over the bulbs.
As @AndyPRK says, one quartz halogen mixed with the small LED bulbs worked, even with 230 volt bulbs. The G4 are 12 volts, so would need a transformer, there are in general two types, toroidal transformers 1739202091073.png have only a maximum output, but the electronic transformer
often have a range one shown 20–60 VA, so the lamps must total over 20 watt and under 60 watt, newer models
have 0–50 VA again as shown, these work similar to the toroidal transformers, except the output in not 50 Hz but in the MHz range, this can if the cables are too long produce RF interference, and it could react with the electronics of the LED bulb, but normally are OK.
To me the problem is until you try you simply don't know what will work. I have a draw of new bulbs which have not worked, so changed, the quartz G9 came in packs of 10, and I have the small ones which came with the chandelier, I have packs of 10 bulbs bought from Tesco while we could still get tungsten pearl bulbs, I should dump them, unlikely to use them.
It is not helped when the package has a large wattage in equivalent, but the real wattage is in small print.
Yes, lots of things are made in China.
However I did not mention China or any other place.
The first mention of it was your reply.
The location of manufacture is not relevant.
Buying products with made up brand names from vendors who can't spell on a marketplace which excels in having zero oversight is.
