Adding aerial socket
Have you ever measured the impedance of a TV aerial or the aerial socket of a TV, despite being quoted as 75Ω they are far from it.
My VSWR meter is designed for 50 Ω, and I have nothing which transmits which is anything other than 50 Ω, however I have use 50 Ω coax for TV, and it is not very good. Making a HB9CV for TV is a bit hit-and-miss, again as to measure the reflected power one needs more power than one receives.
However, we can play with 50 Ω and it is a reasonable assumption that 75 Ω will act similarly. We could calculate what is needed for a balum, but think highly unlikely that many without having studied for the RAE exam will have the slightest idea of what we are talking about. Yes, it was touched on when doing my degree, but all I really needed to say was splitting in the same way as a supply to a 13 amp socket does not work.
Something like this 1741770302316.pngwill have something inside, so the signal is shared. It is not a case of winding the wires together.
I’m curious, have you measured it? How? At 600 MHz?
Yes of course I have, why else would I have mentioned the subject? I have used various kit over the years, a service monitor was always my first choice but these days I usually use a vector network analyser
hooked to a PC.
See above.
I'm surprised you say 50Ω was not very good I've not had the same experience.
Something like this View attachment 375922will have something inside, so the signal is shared. It is not a case of winding the wires together.
I agree, however bearing in mind the extremely poor impedances of the domestic (and for that matter some of the professional) TV based kit I personally have had no issues in my own home (I hesitate to call it an installation - see below) and I have all sorts of bits chucked in for one reason or another.
I have 10 outlets of which 7 are usually connected to a receiver and all are simply teed together, this botch started when moving in in 1994 in the days of analogue with the aerial pointing at Crystal Palace at 25 miles distant. I'd get a very minor aircraft flutter.
During building works around 2010 the aerial got badly damaged by a tarpaulin, I replaced it with an aerial I originally purchased many years ago for a previous property specifically to point at a different transmitter to receive CH5 which IIRC was on channel 65 ish so around 800MHz and as such it is a very narrow bandwidth. When moving house in 1992 I removed it as it was sharing a pole with my Amateur radio aerials. It is now low down on the chimney (below the lashing kit) and roughly pointing at a nearer transmitter, 5 miles distant, which IIRC uses all low 40's channels so possibly 100MHz below the aerials bandwidth.
It's rather embarrassing to admit this:
is one of two of my TV network joints lurking under the floorboards, the brown and white are the feed from the aerial and to the other joint, the 2 blacks are 10m ish feeding TVs, the top is 1200Ω (1.2KΩ, typical of car radio aerials), the short piece of cream is 75Ω and the bottom black is RG174 (3mmOD 50Ω).
The other joint is just the same construction and includes RG58 (50Ω), RG59 (75Ω low quality video type), RG62 (92Ω data) along with regular cheap TV coax with a hint of screening.
One of the presentation events we did included multiple flat screen TVs dotted around the hotel venue, originally we were led to believe we could hook into their UHF distribution system and even shown to the cupboard with the tuners, modulators and distribution amps and allocated a composite video input, however on the day no key could be found so we did a quick botch with ordinary twin flex looped around and teed in various combinations, it was not perfect but it got us out of a hole.
This is only TV we are talking about and now it's digital patterning is pretty much a thing of the past.
I have done daft things, like using a long wire for VHF 2 meter band, when I found I was locked into a container. So yes sometimes we get away with things which in theory should not work, and as far as TV goes, I had a coax take the signal to my living room, and then living room to loft, and loft to bedrooms, so I could watch terrestrial, satellite, and recorded TV in bedrooms, with 14" TV's it worked well, but as we went to 28" the picture quality was not really good enough.
This house not a clue how the TV signal goes from room to room, we have SkyQ and the main box connects to a dish, but as to how other boxes work, not a clue, it works.
I could just use electrical crimps for the split and then solder - solder to increase conductivity.
No, don’t do that. Use the splitter that I linked to.
It’s not about increasing the conductivity, it’s about matching the impedence.
I am curious, what would happen if I did do it? What end-user effects would I see? BTW, it would have worked. Explanation to follow.
Thank you all. The project has been canceled. TV signals have come a long way since the last time I contended with them 15-20 years ago. The signals in the area are so strong that I would have gotten something if I stuck my finger into the aerial socket. All mini indoor aerials work. The loft aerial is basically obsolete. There is no more reason for me to add a socket.
So you have wasted the time of the people trying to help you?
At 2.36pm you were still asking for advice. 53 minutes later- you can use your finger.
Feels a bit harsh, I imagine a little experimenting in the 13 minutes between posts revealed the situation and the lack of requirement to add the additional cable.
Happy to waste your time. For the others, they have contributed to a happier world.
Ot's always the way with NutJobs threads. I’m just surprised he didn’t start telling those that were trying to help him that they were wrong.
People here were not wrong. I gained lots of great tips. The next time I need to do a socket of some type, I will know what to do.
Yes Iagree but it's nowhere near as important as so many seem to state.
The people who designed the modulation and error correcting schemes used in DVB-T spent a lot of time studying quite how bad the signals actually reaching TVs were, and making sure there was enough resilience to cope without everyone having to re-wire.
