UFO / UAP
Status
Not open for further replies.
I see why you are confused now.
Nonsense
“How long will it take to accelerate to 20% of light speed at 5g”.
“How long will it take to get to the nearest star at 20% of light speed”
“Does an object in a vacuum without gravity continue at the same speed without propulsion”
I see questions with no answers.
Forget 10% of light speed, it's never going to happen boyo, Nor will you be able to show anything credible to support it.
Mars is a pipe dream and it's practically in touching distance, in the grand scheme of space.
Far side of our solar system - not a prayer.
Show us this credible evidence you hallucinated?
I wait.....
U hallucinate every day when u wake up Jimmy!!!
U think only 'YOU' know 'EVERYTHING' but you dont!
You just like to hurl abuse about.
You are a sad person indeed...
Plying football on the Sun is not possible.
Humans reaching the edge of our solar system alive (or even half way) is not possible.
The UFO trolls on DIYnot having a rational thought, seems to be impossible.
Jimmy noseall talking sense in not possible...
Just as I said - zero credible evidence.
The wait goes on...
Nonsense
ok now you are just being a silly troll again.
Mars is never going to happen :LOL:
How long will it take to accelerate to 20% of light speed at 5g. =14.1 days
How long will it take to get to the nearest star at 20% of light speed = 21.2 years + 14.1 days
Does an object in a vacuum without gravity continue at the same speed without propulsion = Yes
calculations below:
Q1 ) Calculate how long it will take to accelerate to 20% of the speed of light (0.2c) at an acceleration of 5g, we can use the formula for time under constant acceleration.
First, we need to know the acceleration aa and the final velocity vv.
  • The acceleration due to gravity on Earth is g≈9.81 m/s2g≈9.81m/s2, so 5g is:
a=5×9.81=49.05 m/s2a=5×9.81=49.05m/s2
  • The speed of light is c=3×108 m/sc=3×108m/s, so 20% of the speed of light is:
v=0.2c=0.2×3×108=6×107 m/sv=0.2c=0.2×3×108=6×107m/s
Now, using the basic kinematic equation:
v=a×tv=a×t
Solving for tt:
t=va=6×10749.05≈1.22×106 secondst=av=49.056×107≈1.22×106seconds
So, it will take approximately 1.22 million seconds, or about 14.1 days, to accelerate to 20% of the speed of light at an acceleration of 5g.
Q2 ) calculate how long it will take to reach the nearest star (Proxima Centauri) at 20% of the speed of light, we need the following information:
  • Distance to Proxima Centauri: approximately 4.24 light-years.
  • Speed: 20% of the speed of light (0.2c).
Step-by-Step Calculation:​
  1. Convert the distance to the nearest star into a more useful unit:
    1 light-year is the distance that light travels in one year, which is about 9.461×10159.461×1015 meters.
    So, the distance to Proxima Centauri is:
    4.24 light-years=4.24×9.461×1015 meters≈4.01×1016 meters4.24light-years=4.24×9.461×1015meters≈4.01×1016meters
  2. Determine the travel speed:
    0.2c=0.2×3×108 m/s=6×107 m/s0.2c=0.2×3×108m/s=6×107m/s
  3. Calculate the time:
    Time is distance divided by speed:
    t=distancespeed=4.01×10166×107≈6.68×108 secondst=speeddistance=6×1074.01×1016≈6.68×108seconds
  4. Convert the time into years:
    To convert seconds into years, divide by the number of seconds in a year (31,536,000 seconds per year):
    t=6.68×10831,536,000≈21.2 yearst=31,536,0006.68×108≈21.2years
Final Answer:​
It will take approximately 21.2 years to reach Proxima Centauri at 20% of the speed of light.
Q3) Does an object in a vacuum without gravity continue at the same speed without propulsion
Yes, in a vacuum without gravity (and assuming no other forces are acting on the object), an object will continue to move at the same speed in a straight line indefinitely. This is a direct consequence of Newton's First Law of Motion, also known as the law of inertia.
In simple terms:
  • An object in motion will stay in motion at the same speed and in the same direction unless acted upon by an external force.
  • In the vacuum of space, there is no air resistance, friction, or other forces to slow the object down. Similarly, in the absence of gravity, there are no gravitational forces pulling it in any direction.
This means if you give an object an initial velocity in space, it will continue at that velocity (speed and direction) forever (or until it encounters an external force, like gravity from a nearby planet or star, or some other interaction).
No. Many sighting from going back hundreds of years....
All can be attributed to hoaxes or verifiable phenomena, name one proven example of a proved recovered ufo on which there is widespread scientific consensus, of the the kind you find with climate change.
I see why you are confused now. Newton's First Law of Motion disagrees. Your google calculator will help you.
I really don't think you grasp the scale of what you're describing here.
Status
