For the cutout to allow cables to/from TV check out brush plates that fit over a standard electrical back box
other sellers are available...
Do you know the dimensions of the mounting bracket as it might span two studs then no need for MDF etc
edit.. According to the lg site the bracket is 452mm wide so you might be lucky if you have studs at 400mmm centres...
Single Brush Wall Face Plate Outlet 1 Gang Cable Tidy Entry Hole Cover Plastic
Single Brush Face Plate - 1 GangQTY = 1 Specification Fits a single back boxSupplied with screwsMaterial - Plastic plate with white gloss finish Why Buy? - This brush face plate is a perfect solution if you have many cables needing to exit through a wall and the space you have available is...
www.diy.com
