- Joined
- 28 Feb 2025
- Messages
- 67
- Reaction score
- 4
- Country
Hi all!
I've attached a plan below. Side extension is being built, it includes a WC. Toilet waste pipe will go straight out the wall and then down into the ground on the outside.
I want to avoid an unsightly stack on what will be the front of the house extension. So preference is a low sub stack at ground level, quite short. However, I understand a vent might be needed on it, a special type, meaning it will end up being 1m high.
If you look at where I've marked 'A' in a circle, that is an existing soil pipe with a passive vent on the top, above eaves level. It is connected to two toilets which are located on the other side of the wall from it.
Question: can the new toilet just be served by the existing vent? It would be over 6m from the new toilet but not much more. Perhaps 6.5m. I cannot find information on this specific question as people seem to be talking about toilets sharing a line..?
