I noticed my monthly meter reading had gone up a bit so I’ve been taking more frequent readings and found the house is using half a litre of water an hour when the house is dormant with no known or intentional water usage.
There are no taps dripping (incl the outside tap), the 2 loft cisterns aren’t overflowing, no toilet is overflowing down the pan, no sign of a water leak at the gas boiler, washing machine or dishwasher, no soggy carpets under radiators, no damp patches of wall or ceiling and no musty smells anywhere.
If I turn off the main stopcock in the house then the water meter stops and shows no consumption/flow.
As there are no clues then I'm assuming the leak is probably from a joint that’s leaking into the external wall cavity and draining through the foundations, but I’d welcome other theories.
So I’m now stuck as to what to do next to diagnose the problem other than wait until something bad happens/appears.
Can anyone help with ideas to further diagnose?
TIA
Mike
TIA
Mike
