[SOLVED] Is there a piece to extend a flexible tap hose?
5 Apr 2025
Hello all. Please see photo below. This is for a bathroom basin.
I remembered too late that my hot water pipe is shorter, so I need flexible tap hoses of 2 different lengths.
Problem is I cannot remove the hose from the tap (can't reach the nut).
Am I condemned to buying a new tap, or is there a piece I can fit here to fill the gap between the water pipe and the flexible tap hose? I went to my local DIY shop but couldn't see anything looking useful.
Thanks in advance!
Not too sure if there would be enough length in these, you will need a nut and olive to fit the ISO valve though
Thanks Rob, unfortunately I think these are too short. And I need something which is 15mm on both sides...
@Madrab alternatively would you know what tool I could use to unscrew the flexible from the tap? Basically it's too far inside the tap casing, I cannot reach it with a spanner, I have no idea how this got screwed to start with. (I received the tap with the flexibles already attached)
Flexible hoses don't seal by being tightened to oblivion, they have a rubber O ring on the end of the bit that screws in. As a result they might be loose enough (if whoever fitted them had the wherewithal to not tighten them to oblivion) to just undo by turning the flexible hose, as high up as you can reach, and then fit a longer one
Is there any give in the copper pipe? A clip somewhere you can remove and bend it/pull it up?
Got a Screfix nearby?
@robinbanks It was my original plan to remove the flexible and put a longer one (I have a few already) but I just can't remove it, I have no grip at all on the attached end. No give in the copper pipe at all either.
Thank you all for your help. I bought the piece from Amazon, as I couldn't cancel the purchase, and if it doesn't work, I still have the option of using a radiator valve extender.
The only problem with the amazon part is you won't have a rubber seal, that would need to be added into the fitting to create the water seal @ the isolation valve, otherwise it would need to be PTFE tape.
If you're prime then normally there's free returns.
