Then it is probably a radial for the cooker outlet only, but you had better get a qualified electrician to check. There are Schemes had hold registers of members. This is one example, there are others. https://niceic.com/find-a-tradesperson/Thank you - the photo of the circuit breaker on the fuse box is below.
You can still get cooker switches that have an integral socket, I have some. Handy for a built in oven plus a microwave or other appliance. They are a bit big but mine were carved into the wall when the house was built.
Modern ones can be a bit smaller but still need a deep backbox. The cables are rather thick. The cooker cable is typically connected to an outlet behind the cooker or below worktop level, but controlled by the visible and accessible switch.
I have been very happy with the quality of the Crabtree one
