Drill a hole in the middle of the tile. Using say a plugging chisel or similar, peck away at the hole working outwards. The bits closest to the grout line will begin falling out. Go buy yourself a new white Metro tile and fix.Hi all
I have this wall tile thats cracked and need opinions on how to repair it as i cant replace it as its in the middle of the wall.
Any help would be appreciated
Kind regards Mark
Easier to remove tile and replace with new one if you can get a matching tile. Carefully rake out the grout around the tile. Then once again very carefully, with a hammer and chisel or flat blade screwdriver break the tile up and ease the pieces off the wall. Remove any adhesive left behind tile with hammer and screwdriver/chisel, apply new adhesive, tile and regrout around tile - aiming to get a grout that matches the rest.
Poss plenty of videos on Youtube how to remove single tile. Keeping old tile and trying to fill the damage is never going to be pretty.
Removing the grout can be risky to the surrounding tiles, especially if there are placcy spacers in the corners. Destroying the tile from the centre out, takes the tension away from the joints and means that the unwanted material closest to the good tiles, just falls away.I use a blunt blade on the multi tool to rake out the grout then chop out the broken tile to renew it.
You could just chip out the broken bit and fill the hole with grout-depends on how fussy you are....
Rubbish, nothing risky about it the way it has been described to do. a multi tool would cut through any plastic spacer easily leaving no damage. taken plenty of tiles out by removing the grout first, once the grout line is cut there is no pressure on the surrounding tiles.Removing the grout can be risky to the surrounding tiles, especially if there are placcy spacers in the corners. Destroying the tile from the centre out, takes the tension away from the joints and means that the unwanted material closest to the good tiles, just falls away.
There is always a risk of collateral damage when messing with the grout. Although those joints look wide, you only need twist the tool slightly and you have a problem. It sounds brutal, be removing the tension from within the tile is less risky.It depens on how good the grout is.
It's the way tilers do it. You won't see them faffing about with the grout.Yep, that's definitely another way of doing it.
Stick to changing bulbs, Billy.Rubbish, nothing risky about it the way it has been described to do. a multi tool would cut through any plastic spacer easily leaving no damage. taken plenty of tiles out by removing the grout first, once the grout line is cut there is no pressure on the surrounding tiles.
Will do. You keep painting those window sills.Stick to changing bulbs, Billy.![]()
