- Joined
- 18 Feb 2025
- Messages
- 169
- Reaction score
- 7
- Country
Thanks. These are only dry fitted so the chrome fitting may push in a mm maybe more. But I'm guessing advice is to follow the installation manual and cut both pipes so they are 10mm-20mm proud of the gold bracket?As mentioned before - If this is the way the copper pipe is with the olive inserted and the 3/4"chrome compression fitting tightened, then it's fine. If anything the pipe on the right will need to be trimmed by a few mm so it's flush to the chrome fitting
As suggested - a manual or instructions are not needed. This is stuff we do without any thought or instructions needed as it very straightforward and only works one way.
Currently the one on the right is 25mm and the left is about 22mm
This would probably mean the pipes won't be flush with the chrome fitting and be set back a little
