Apart from convenience which is a major consideration in many aspects of modern life.Heating water instantaneously on demand is a failed concept.
What is your view on kettles?
Yes they do, and car manufacturers have always done this for reasons which should be obvious.Do EV makers produce special versions of their cars for the UK market,
Many other countries have 3 phase as standard.in other countries higher charging rates are supported,
Good luck with that on a 60A UK domestic supply.IEC 61851-1 Mode 3 allows 63A single phase.
2x 32A EVSEs, which are linked so that the maximum output is 7kW between them.Note, they did say 3.5, which left me with the impression it's more like a portable charger with a 16A blue plug, not a "ChargePoint on the house"
A kettle is not an instantaneous water heater.What is your view on kettles?
Stored hot water heats up with no user intervention using whatever energy source is most appropriate.Apart from convenience
Then neither is your what you are decrying.A kettle is not an instantaneous water heater.
It appears to be you who is bothered.If people are bothered by using such things, then boiling water taps exist to avoid filling a kettle.
...and if not used is wasted.Stored hot water heats up with no user intervention using whatever energy source is most appropriate.
Do you mean like a combi-boiler?You turn the hot tap on and hot water comes out.
No inconvenience involved.
Who are these people that heat up hot water and then go on holiday for a week?...and if not used is wasted.
From the end user perspective it's similar if only one outlet is in use and they have a gas supply.Do you mean like a combi-boiler?
32A and 4mm² *could* do the job.I appreciate a 32a RCBO and 6mm2 TE cable *could* do the job, but I'd rather oversize for safety.
Oversizing cables does not improve safety. It costs more and makes it more difficult or impossible to terminate the cable into the equipment.but I'd rather oversize for safety.
Doesn't exist. There are no places anywhere in Britain where you could be too far away from a charging facility to run out of charge before you got to it.range anxiety
It's a thread in Electrics UK; par for the course, and this one is actually reasonably in hand still, IMO!Sorry but I think this thread has gotten a bit out of hand.
Safety is the RCBO's job; don't oversize thatI'd rather oversize for safety
Particular aversion to using a charger that takes an IoT SIM?and optionally to use for the internet connection.
People tend to forget about oil combis, of which there are plenty around. There may even be combis which use some other fuel, although I can't think what that's likely to be..... where gas is not available or wanted, a combi boiler is of no use.
You mean like they have more than one 13A socket, or more than one lightbulb?
Seems like a not-unreasonable idea if I'm honest..
There's no change in physics required, just a change in the attitude that refuses to accept that the physics would allow a different solution for people that want it because they don't think they should be allowed that freedom of choice.It's the behaviour that needs to change if the physics cant
I don't think that any manufacturer would decide to build multiple types of charger and put different types into his products unless he had to.Yes they do, and car manufacturers have always done this for reasons which should be obvious.
Most products are specific to the markets in which they are sold.
I was talking about single-phase charging. I'm sorry that you weren't able to understand that from the closely following sentence about IEC 61851-1 Mode 3 allowing 63A single phase.Many other countries have 3 phase as standard.
Not everybody has only that.Good luck with that on a 60A UK domestic supply.
I also think that there is no point whatsover expecting you to engage in a rational discussion on this topic.They apply a massive peaking load to the supply
They are entirely incompatible with solar, hot water storage, battery systems and TOU tariffs,
Impossible to have more than one in a property without non-trivial supply upgrades or switching malarkey to ensure only one can be used at a time.
Combination boilers belong in the same bin.
