As the headline says,which brands are worth looking at..... I'm replacing a Gainsborough which has really low flow rate...... I wasn't aware of that when I bought it but looking at specs of others now it explains a lot
Cheers
Most electric showers are inferior flow rates due to the nature of their design. Mira are usually a good offering, Aqualisa is overpriced imo Triton can be hit and miss.
Will depend on water and electricity supply, as to the performance you get/what you can have. You'll be limited to 6-7kW if on a 32Amp/6.0mm cable supply, if you've got a 45 Amp/10.0mm cable on the supply, you can look at the 10kW units, which will heat more water, faster to give a better output and shower.
Look for a 10Kw version then. One which automatically adjusts to maintain a steady temperature, is much better, than one where you have to adjust the flow, to set the temperature.
