- Joined
- 18 Apr 2022
- Messages
- 5,080
- Reaction score
- 620
- Country
There are so many types of LED bulbs available nowadays that I'm not sure what the problem is. I've got glass quarter-sphere wall lights, two designs of outside lights, and a couple of flush (not recessed) ceiling lights where I've standardised on bulbs like these:
("Standardised" because I'd rather not have to keep loads of different spares).
Any of the lights would accommodate GLS bulbs, but with some I wouldn't be able to get my hand inside the fitting with bulbs that size, and with the glass wall lights the light source is offset to one side too much.
You can get switch-operated CCT ones, if you want.
I've also got some pendant lights to install, very similar to this
where again I'll probably use those LED ones (I think the lights were designed to use tungsten candle bulbs).
I don't recognise this "problem":
... even worse, a fitting designed for tungsten lamps, which have a compromise LED fitted.
